Everything was working on Saturday, though I noticed the AC wasn't particularly cold.
Nothing worked on Monday. No fan, either on Auto or Manual, AC on or off.
Swapped the fuse and the relay, with no change.
I've had resistor packs fail on older Mondeos so thought I'd check that.
Got the glove box out and there's some funky new wiring between the large lilac strip wire in the large plug and the loom.
Looks like some one has added an inline fuse ? I see the lilac wire is a problem, but usually in the engine bay loom ?
The resistor pack module thingy looks ex scrappy to me and is dated 100114, whereas the car is a 2010 plate. I've had it since 01/2018.
Can it be tested out of the car or do I just swap it again ? Looks like they're about £20 on Ebay.
