Lots of info on this topic if you do a search.
Please see pics below on filter replacementfalconmicky said:Thanks for the link Mondeo-hopeful, I've had a look, but was hoping for a bit more detail & photos. Have also tried Youtube without success. has anyone else got other suggestions please?
If it gets clogged up you will notice it - the airflow from the HVAC will be greatly reduce (you'll really notice this if it's hot outside and you need to use the AC). Over here I need to change mine on an annual basis, due to the air pollution.Have to say is it worth it? Does anyone notice when the filter is changed?
Had mine done in 3rd service last week and for all i know it hasn't been changed or if it has i can't tell!!!
The airflow through my vents seems better with the fan having to be set on one speed slower for roughly the same output through vents. Aircon seems slightly cooler too.Have to say is it worth it? Does anyone notice when the filter is changed?
Is the filter re-usable? Or do you need to get a new one from Ford? If no, how do you clean it?Just changed the pollen filter for my 3rd service yesterday.Only 23k on the clock,but was surprised to see how dirty the old one was.Not as big a drama as a few on here are making out.
Remove the plastic trim from the centre consul in the passenger footwell. (1 plastic stud)
Remove the soundproofing covering the fuse box (2 yellow clipnuts)
Turn the retaining thumbscrew holding up the fuse box and drop down.
Remove the plugs from the outer of the fuse box (Big blue one,big brown one,big purple one,small black 2 wire one and one smaller wired black one)
Remove the fuse box completely.
Remove the 2 x 7mm Hex Head screws holding cover on.As pictured in thread above.
Slide old filter out,noting direction arrows printed on side.
Fit in reverse order.
Bit awkward to get to,but easily doable with basic skills.
20 mins tops.
