1 - 20 of 20 Posts
I would love to help you...but I can't fix stu
Did a switch in Carbon Fiber Vinyl. tinkering with the idea of the whole dash in this. Opinions???
MEG's resident oven
looks ok but wil be very very fiddly getting the curves done correctly in vinyl wont it?
at Vanishing Point....
You've got more patients than me. And I'm pretty patient lol
Looks good. I'd say go for it and do all the dash panels :L :first:
The biggest key point to it is to use some water with a bit of washing soap in it. This keeps it from setting directly on contact. It gives you a bit of time to set it right. Also, a hair dryer or heat gun does wonders to soften the vinyl and give it a bit of stretch. As for working with it, as long as you go slowly, the curves aren't that big of a problem.
Cheers,
MEG Admiral
i did a bike for someone a couple of years ago, and i used a scalpel as opposed to stanley knife and it was easier to cut because you have more control over it, you can get them off ebay for about £4 delivered for 10, but if you only want 1 pt me your addy and ill send ya one :L
Been thinking of doing the same thing when I spotted a carbon effect dash kit on ebay. It appears to be pre-cut vinyl, possibly a bit thicker. It's only for the lower half though.
Discussion Starter · #10 ·
Another thing with it, the part has to be completely clean. So quite a good couple of rubs with some alcohol and presto this stuff sticks like crazy glue.
Im Back !!!!
Looks good on one switch, but i think it might be a tad overkill if you do the whole dash with it.
Couldnt you just do all the removable switches rather than all the surrounds.
Discussion Starter · #13 ·
Well I have second complete set of panels so I think that i am going to give it a try and see how it looks.
Discussion Starter · #14 ·
Here is the next bit with the vinyl on. Will hopefully get it in the car tomorrow for shots and opinions.
Cheers,
Discussion Starter · #16 ·
saw something similar to that and got my idea from it.
I did the pics
TheDude said:
Looking good m8 :)
Anybody ever seen one of these in a car?:
Dash kit
Yes, and they look terible fitted. They're too stiff (ooeer) and dont bend round the curves. Ford actuall do a kit like that for wood effect! It's pants. Much better to do the vinyl. I trimmed the ash tray in my old Mk2 in carbon fibre effect vinyl to match the ST200 speedo surround and door inserts
MEG Admiral
looks good phil :L
Discussion Starter · #19 ·
First piece installed. Have changed my mind and now going to leave the walnut dash bit in and do the rest in the vinyl. A bit of half and half.
Cheers,
TheDude said:
Looking good m8 :)
Dash kit
certainly have m8, previous owner of my last done up car bought a set and fitted himself..it looks a bit tacky (doesnt even try to cover the whole panel..)and peels off after a while...
if you had the patience to cover the whole thing it might look better..
not worth £103.00 :headshake:
1 - 20 of 20 Posts
