Hi
Trying to get to the bottom of my issue with this P00BC code (no other codes reported by car). I have replaced the MAF sensor but still get the same issue which suggests an air intake leak as the code refers to air flow being low. Where would I start to see if there is a leak? Where could this leak be if airflow is too low? I have replaced the air filter. The air filter box has a broken corner that slightly exposes the air filter but not much. Surely it's not leaking too much here? Or maybe it's not an air leak? After clearing the code, I can drive anywhere between 10-30 miles before it shows up again and the car goes into limp mode, losing power.
Any help in getting to the bottom of the issue would be much appreciated.
