I'm getting poor starting and glow plug light its wont Rev up and it's chugging out gray smoke and sounds like its not running in all 4 cylinders after two mins of this if you restart it it will run ok and Rev up as normal
It's showing p1328bfinded tdc but I can't find what this relates to
I'm sure it's got to be a injector problem
Yeah most likely P132B. That will cause a lack of boost and limp mode.
P1328 = Cylinder 12 high/low side open. So not applicable to the Mondeo.
The poor running maybe another issue though. What code reader are you using?
Some cheaper ones dont show all the codes.
I agree with all the above; the P132B might be in addition to the poor starting fault , easiest way to check this is to clear the error, disconnect the turbo actuator arm (don't lose the circlip!) and run the car for a while like this. If you still have the poor starting issue, it might mean 1 or more glowplugs are burnt out and need replacing.
