1 - 19 of 19 Posts
hey guys
i still dont know so i took a few pics of my engine bay!
lol
alll are around the air filter / battery
tell me if u spot anything to suggest wether its cable or hydraulic.
next to battery;
under airfilter; and around there
TDDI Buff
cant see a lot too much stuff inthe way :(
speak to doompixie he's got a cable operated one.
Yo
Looks hydraulic to me - you can see the pipe best in the secon pic, follow that back and it will go to the brake fluid resovoir as it shares the fluid with the brakes.
TDDI Buff
ah thats better!! :L
yeah ifit goes to brake master cylinder it wil lbe hydraulic :)
are you talking about hydrolic gearchange or hydrolic clutch? is there any hydrolic gearchange on mondeo at all?
the clutch seems to be hydrolics but i can't see on the pics cable gearchange which might concerned you more. so it is either under/behind the shiny block of metal on pic4 as there are 2 cables going under it, or might be rod gearchange usualy going in to the gb behind it
so is it definately rod/hydraulic? coz in that 2nd pic mrT i think ur takin about the pipe that goes to my FSE valve, vauum pipe - black one,
thanks, any more info would be apreciated,
john
TDDI Buff
at the bottom middle of the pic praxis put in is a bleed nipple same as you get on brake calipers look for that on your gearbox if you got one its hudraulic its on the top of the box iirc and the pic looks similar to your first pic if thats the same sort of copperish looking pipe.
Discussion Starter · #9 ·
took my car to a garage today and he said it was definately hydraulic,
gutted, need to source another box now!
Yo
john
No I was talking about the metal brake pipe style pipe that is right next to the gearbox caseing.
However, can you not still use the gearbox you have found?? I may be wrong but can't you just seperate the bellhousing together with all the clutch gubbins from the gearbox, and then attach it to the new box??
Discussion Starter · #11 ·
hmm i dont have a clue, didnt even think of that m8,
i think ill ring my local garage who ive been recommended to for a gear box drop in, tomorrow morning and ask them!
thanks alot every one!
john
TDDI Buff
should have done that in the first place :eyesup:
Discussion Starter · #13 ·
i did but its cable, now im gona have to find a different one,
TDDI Buff
i meant before you posted this thread
Discussion Starter · #15 ·
i did lol, then the chap said its cable, didnt realise tehre was 2 types so then i posted this thread to find it what mine was :)
TDDI Buff
im lost now.......... you took it to a garage and you were told you had a cable operated gearbox is that right? then you posted you took it to a garage and said it was hydraulic?
Discussion Starter · #17 ·
DOH! lol, nope
i was offered a cable operated gear box from a megger and i didnt know that there were different types of boxes until he said "its cable operated" so then i posted this up,
and then after that i went to get my car checked at a garage :)
hope that explains all
TDDI Buff
ok i see now which is what ithought in the first place it would have been easyer just to goto the garage and get yours checked straight after you got offered the cable operated box.
Discussion Starter · #19 ·
yea wud have been lol!
1 - 19 of 19 Posts
