1 - 2 of 2 Posts
Hey guys, I had a leak from the PCV area so I swapped my PCV Valve and gaskets and hoses. Check out the vid if you need some tips.
Mine was leaking from the rear hose. It seems that this collapsed under vacuum over time, causing a leak where the metal pipe connects to the rear hose.
Hope this helps someone out.
1 - 2 of 2 Posts
