If you have a sensor on your EGR then you have a Euro 4 model. It senses more than just open and closed as live diagnostic data shows EGR flow as a % figure which changes according to driving conditions. AFAIK it's only TDDi models that don't have a MAF but even so, I'm sure all Euro 4 models have a MAF.
Be interested to see how you are proposing to bypass the EGR, I used a blanking plate and drilled larger & larger holes until the engine warning light didn't come on and ended up with a hole so large it wasn't worth having the blanking plate fitted!
I do know that I've just cleaned my EGR valve out after only 6,000 miles since last cleaning it and had a fair amount of sooty crud to remove, I'd certainly like to bypass mine permnanently.
