Hi all,
So it seems I have had an issue with the dipped headlights for a while and never really noticed. Either the dipped headlights aren't working properly or the auto sensor isn't.
So starting with the headlight control in the 'off' position;
I move it to 'sidelights' and a green indicator ( with two lights pointing outward ) appears inside the rev counter and the Convers display shows two beams coming out the front of the car ( is this correct ? ) and the actual side lights come on.
Move it on to the dipped position and nothing changes on the dashboard/Convers and the dipped headlights come on. ( Is there not an indicator for dipped beams ? )
Move it to the autosensor position and nothing changes.
Turn on main beam and an additional blue indicator appears inside the rev counter and the main beams come on.
The dial is left in the autosensor position all the time.
For as long as I can remember this has caused my car to always be driving with just side lights ( but Convers showing both beams coming out the front ) when lights are needed. [ Don't ask why I have never noticed
Short term I can just not use the autosensor and use the off/dipped positions but ideally, long term, I would like to get it fixed.
Given the above, is anyone able to shed any light on what the issue might be ? It doesn't seem like a bulb problem and sounds more like a wiring one to me ?
TIA for any help.
TIA for any help.
