1 - 2 of 2 Posts
Hello,
I have had a blanking plate with a hole in my Mondeo tdci 130, i recently found out that it is a Euro 3 so I can use a full blanking plate...
This evening I swapped the blanking plate with a hole to one without a hole.
I took the car for a long drive, stopped a couple of times, turned the car on and off..
Ever since the EGR has been blanked I have had hesitation when accelerating, when below 2500rpm, when above this and i accelerate it doesn't hesitate and feels faster than it was previously.
I think i'm going to put the one with the hole back on as I don't know what else to do.. Please help or suggest what could be the problem, it was fine before the full EGR blank.
then put the one with the hole in back in . . . the egr blank is usually only recommended to test the egr anyway . one with a hole will probably act like there is no blank in the egr anyway so the egr on your motor is probably working fine anyway ..s
1 - 2 of 2 Posts
