ever since i replaced the cambelt i've got quite a kick at start and a permanent (weak) vibration at idle.
the relation(through the belt) between the crank and the cams at the moment is dead spot on. i.e. cams locked and the crank pulley aligned at the second mark with the back of the sump raised mark (haynes) as per pics.
(some will say use the pin but when everything was set with the pin i have fully inserted i had heavy pinging, so at the moment i dont have pinging but the simptoms above and the pin sit 3-4mm out the one i've got is 2" +1/2"+3/16" it is not 2 1/2").
The question is how can i set the timing in order to avoid the kick(i suspect increased compression) at start and the vibration(might be caused by opening the valves early or late and when i touch the top feels as misfiring)?
