MEG Commander
window was smashed in a bump a while back so im going to replace it today. (back drivers side)
no idea how to do it though :whistling:
anyone know??? :L
Remove door panel
plastic sheet behind the panel,
depending if shes wind or electric window lower the regulator down untill you see the two bolts holding the glass into place
simply undo them and the remains of the glass will fall out.
probably have to remove the outewr window trim.
put the new window in from the outside,tilt it then she will slide into the door
drop the glass between the plastic holder and insert the 2 bolts
tighten them up and make sure the glass sits in the runners and that should be it
replace trims etc
I would love to help you...but I can't fix stu
pretty much sums it up right there. I would add one other thing though. You will probobly need to run a screwdriver around the whole window seal to get the bits of glass out of there. Oh and a good hoovering of the glass out of the bottom of the window. Used a shopvac to clear mine as the wife would have shot me had I used the good hoover!
It is an easy job though, took longer to get the panel and plastic sheet thing off the door than it did to get the glass in and out!
MEG Commander
cheers lads, done today :L :L
