Hi Neil
I had the exact same on mine.I didn't notice it on the test drive or driving it home.
Only noticed it when my wife sat in it started the car and put her foot on the clutch without engaging the gears and it was clearly audible.
Also you could feel it through the pedal.
Also if you just touched the clutch down slightly you could hear a ticking sound.
Took it to my local ford who corfimed it was the flywheel.They didn't take anything apart so they must know the sound of a deteriorating DMF.
They wanted just under £1500 to fit a flywheel and clutch.
I had to take it back to the supplying dealer all done under warranty.
Take the car back at the next earliest time you can.
I was nearly a week before my local ford could book me in to look at it and then nearly a week again before i could get back to the supplying dealer.
Within this time the noise got considerably worse.
The job itself is around the 6hr mark.
Mine is an 04 with 60000 on the clock.
If you pop the bonnet and get someone to depress the clutch stick your head under and you can clearly hear it coming from the bell housing
HTH
HTH
