Is the turbo boost sensor the same as the MAP (Manifold air pressure or something.. Think it measures the air pressure in the inlet manifold - but I could be wrong)?
heres cheeky......martin105 said:Cheers guys for the help, so it sounds like the turbo boost sensor is also known as the map sensor, i've been looking around the turbo unit, the haynes manual does not mention the turbo boost sensor.
Thanks folks, much appreciated,
regards...Martin.
