Rear anti-roll bar links how easy to change?
1965 Views 1 Reply 2 Participants Last post by  tonytraff55
Got the new ones and look easy but are they?
Do you just unbolt them, do you need the rear wheels off the ground?
Do they align up ok or do you need to put pressure on the other bar to get them to align?
Cheers.
1 - 2 of 2 Posts
i jacked car up took wheel off easy access safer than lying under the car took off old ones there is a little pressure on them when renewing you can push the roll bar down a bit to catch the new nuts on top the link then do them up..i beleive though if you dont jack the car up and just lie under neath they shouldnt require no more than just undoing old ones and fitting new ones in place.. :content:
1 - 2 of 2 Posts
