Need more mods, any ideas?
i am getting a clonk, say if i reverse then hit the brakes or move of slowly and brake or pull of quickly i get a rattle like clonk.
all i can see that looks suspect is the Rear Roll Restrictor, all the suspension parts look fine.
how much play should there be in this item? i can put a screw driver in one of the rubber holes at the bottom (with car on jack) and get the centre bolt to move a good 10mm or so.
could the Rear Roll Restrictor give me the clonking issue? if not any other ideas?
thank you in advance.
oh the problem is with the hatchback......
James_McHattie said:
http://www.jimmycricket.com/pages/Rollrestrictor.htm
yeah cheers, i have read that. it is that part, how much play should there be?
