1 - 1 of 1 Posts
Hi, My MK3 Mondeo went into Fords today for its yearly service. With it being only two years old I thought that everything would be fine with it. Unfortunally, that was not the case. Fords came back with three faults which luckily are being the fixed under the warrenty. The first was a leaking crankshaft oil seal. Secondly was sleeves over the rear springs were split and hanging off and thirdly the subframe bushes on the rear were split and wore. For only being two years old I thought the bushes would have lasted longer that? The guy at Fords said that they would install a new type of bush which needed to be glued in? Does anyone know anything about these new bushes or had them put in? Thanks.
1 - 1 of 1 Posts
