Seems cheap.
Hi Tony, I would be interested in a copy of the write up and pics if possible. Regards,Hi all.
If anyone needs help with changing the 4 rear bushes to polly ones, I could help. Just done mine and it took 5-1/2hrs, this included doing the anti roll bar. Have some pictures of the work and a full write up of how I did it.
Hi TonyHi all.
Fit original style using a tool, search ebay for Mondeo bush tool or a home made version. They should be fixed using Loctite 648. Note that there are different bush shapes front/rear and the orientation probably should be the same as the old.With regards to the metal sleeves, do these HAVE to be pressed out/in? Is there anyway I can put new bushes with the metal shells on myself?
Nice one. When you say fixed in with loctite, is this if you leave the original metal shell jn and just replace the rubber inside? Im intending if possible on fitting the new bushes that are already in the metal shell. Cant work out if the tool is capable of getting the metal shell in and out of the subframe.Fit original style using a tool, search ebay for Mondeo bush tool or a home made version. They should be fixed using Loctite 648. Note that there are different bush shapes front/rear and the orientation probably should be the same as the old.With regards to the metal sleeves, do these HAVE to be pressed out/in? Is there anyway I can put new bushes with the metal shells on myself?
Original equipment bushes are rubber bonded to the metal outer so you have to remove the shell, they can be destroyed in the process (see the first post in this thread). Poly types are not bonded to the shell, only the rubber and inner are replaced. The outer shell stays.Nice one. When you say fixed in with loctite, is this if you leave the original metal shell jn and just replace the rubber inside? Im intending if possible on fitting the new bushes that are already in the metal shell. Cant work out if the tool is capable of getting the metal shell in and out of the subframe.
