Hi all,
Can anyone tell me the diameter of the lip on the lower (wider) end of the outer cup (the bit of the OE bush that stays in place when you fit poly bushes)? I want to make a tool like the one Master-of-none used in post 110 to remove the old inner bushes - his method seems the best as no need to lower the subframe and lose alignment if you do one at a time. I suspect I can even leave the wheels on and have the car on ramps (with suitable secondary support etc.).
My only concern is making sure the new bush top lip pops into place with so little clearance (subframe NOT lowered) but Master-of-none reckoned all 4 popped in OK as long as you stick a screwdriver between the subframe and chassis to stop "squish" in the remaining bushes.
Thinking of using the Flo-Flex bushes as they're only £20 on eBay; most people seem positive about them although one negative in this thread. Any comments?
Thanks in advance,
A
Thanks in advance,
A
