1 - 7 of 7 Posts
MEG Captain
I put the rear washer on yesterday and instead of going on the outside of the car, it came inside!!
I think the hose may have come off or split? I also noticed there was quite abit of condensation in the brake light.
I just wanna know which side the hose runs from or is it both? Also if I take the brake light off and clean it up is it ok to silicon it back on?
Cheers
Ugly Little Mo Fo
iirc pipe should be around rear r/h door under the roof lining the connector should be there m8. as for rear lights you can dry em out and replace using a bit of silicon sealant( common prob).
hope this helps :L
G
I would start by checking where the pipe joins the nozzle in the light housing. If you remove the plastic trim from the top of the hatch and the high level rear light you will see the nozzle and the pipe.
We had this happen on our hacth and it took less than 10 minutes to sort.
Jeff
TDDI Buff
look in motor driven section theres a thread there i posted in a few weeks ago i think its on page 2 or 3
1 - 7 of 7 Posts
