Hey all,
I recently installed a rearview / reverse / backup camera (it has a lot of different words but you all know what I'm talking about).
Just want to share how I did it!
- SCREEN:
So first of all you need a head-unit with a screen or a screen by it self. I went with the Pioneer AVIC-F9220BT which i am very much pleased with.
- CAMERA:
Regarding the camera I went for this: http://www.ebay.com/...=item23267133ef
It is cheap but it's specifications is not to be found any better anywhere. I have been using this for a month now and I am very pleased with it.
The view in the dark is remarkable good.
- WIRERING
To start with I tried the cable whick followed with the camera but it had no isolation so the picture wasn't anu good.
There fore I used this double isolated cable which realy made a difference: http://www.av-cables...abel-7-5-m.html
It is 7.5 meters long and it was almost to short. I had about 0.5 meter left!
Now. First I tried replacing one of the numberplate lights with the camera but as I feared the lightning was crap and it looked worse than ugly. So I came up with an other idea. Pictures says more than word so i ended up doing this:
I had to grind the sides of the camera off to make it fit. Also some of the cone-shaped thing where the screw goes through.
Then I began pulling the big Composite wire around the car.
All the pictures from my installation can be found here: http://www.adrive.co...era install.zip (114MB and contains about 50 pictures of the whole process)
The power to the camera comes from the reverse light.
Some of the "milestones" from my installation:
I had to to grind some of the cable down so it was able to go through. Use a lot of WD40 or silicone and have patience.
This is the OBD-II plug at the driver side. From here it should be no problem getting the cable to the radio.
This id what I used to make the square cut for the camera. The result ended up being really good.
All in all a super installation. I took me about a weekend all in all and I am more that happy with the result.
FUTURE PROJECTS/IDEAS:
- LED reverse bulbs so there will be even lighter when reversing in the dark.
- Reverse bulbs with built in IR LED's to have "hidden" nightvision
- A switch in the back so I can choose if the camera should be on all the time or only when reversing. It could be a good thing to have in on all the time it you are driving with an trailer behind you.
I hope someone can use this.
Good luck.
Regards from Denmark!
- SCREEN:
- CAMERA:
- WIRERING
Good luck.
