1 - 12 of 12 Posts
Just pondering on the feasibility of rebuilding a V6 bottom end?
The block could be re bored to 88.9mm with 3.0 pistons replacing the std 2.5 82.4mm
The crank bearings is the only stumbling block. I suppose the crank could be reground, but there are no oversize bearings available..... Again a completely new crank could be purchased, but at ££££ bucks!:shocked:
As the engine is used by Mazda and jaguar, and has been in production since 1993 I don't see and logic in why there are no oversized bearings available? :loopy: :loopy:
Window licking mong
is there any stroker kits available for the V6 in USA? i found a kit for the 2.0 zetec which takes it to 2.3 but it was pricey for not alot of power gain
I'd be wary of slapping the bigger pistons in as the liners might get a bit thin and start to flex a bit....
You can get the bits from Autocraft if memory serves tho.
ST200 baby
yes but i am sure i got told the ST220 V6 3.0L lump has the same V block as the normal V6 and they had bord it out with 3L pistions and added a few extra holes for exra water/oil cooling , so cant see why it would be a prob , there are a very strong lump to play with..
I had a problem getting oversized bearing for a reground V6 the ford ones were too small. That is until I discovered that the nissan maxima 2.4 V6 uses the same block and I was able to get the correct size bearing from Nissan!
Discussion Starter · #11 ·
Nissan :confused: Thanks for the info!
Do you have the year, and engine code you had the bearings for, this my be worth checking out!
I think its the maxima V6 (engine series VQ) but this was only a 2.5 not a 2.4.
(the same block was used in the 3.5 350z, Imagine that, a 3.5 mondeo :} there’s even a 4.0 variant used in the frontier)
thanks again :thankyousign:
1 - 12 of 12 Posts
