1 - 16 of 16 Posts
Okay, say if i was to rebuild my engine, how difficult would it be?? and price wise, to service and replace to give me many more yrs of happy driving, and id like a little bit of power, how much we lookin at??
Cheers
Wibble :D
Turbo Boost Me!
How long is a piece of string
Could need a grind and shells, Pistons and rebore
In that case it would be £500 ish
There was a cheap low milage auto blacktop engine on ebat for £125 buy it now, That is VERY cheap for a blacktop engine
It's not that difficult to rebuild an engine. It would be best to know the torque on all nuts and bolts.
When I rebuilded my engine, I cleaned all components, checked them, and replaced them with new ones if not good enough.
I would recomend, like Avinitlarge said, new shells on the crankshaft and on the con rods, new pistons and rings, a honed block, a little skim on the cylinder head and new gaskets. Pluss maybe some new exhaust valves if they are dirty (or clean of the carbon). When I did mine, I also did the valve seats with a special tool.
I bought much of the parts at Burton instead of Ford, because Ford has stopped producing some of the parts for old Mondys.
This costs a bit of money I now too well, but I see you have a mk2, so i presume that the engine isn't quite killed like mine was.
You should also get some other components like oil filter, plugs and so on.
And maybe get a new clutch when you have the box out...
Turbo Boost Me!
And belive it or not, Ford are quite cheap on engine parts, I used all genuine gaskets and seals, genuine piston rings, A valve and lifter shims. The shims were cheaper from ford than after market ones.
what sort of costs are the ford gaskets and suchlike? out of interest as planing on building a Zetec Turbo soon for a nother project..
Also, do ford do a tradeclub card like vauxhall?
Ta
Turbo Boost Me!
Ta
Ford do trade but you need a letter head from a garage, What gaskets do you want prices for??
well i can get fel-pro gaskets through work no problem and i already have a Vaux & Halfords Trade card so a ford one would come in handy...
Was after the gaskets/sets for a 2.0 Silvertop rebuild.
Cheers
Turbo Boost Me!
I wouldnt bother with a felpro, Ive heard loads of bad stuff about them on passion ford, The Std MLS focus RS/Blacktop gasket is only about £25 from ford
Turbo Boost Me!
I will dig through my invoices, My gaskets are all blacktop ones so the prices may vary
Turbo Boost Me!
I advise not using CVH manifold for what ever you are doing, Been there and done it, The results were poor
Turbo Boost Me!
Both, Use the RS1800 HO manifold and havea CVH manifold altered so it bolts straight to the zetec head
1 - 16 of 16 Posts
