if like mk2,which i think it is ,the bumper is pretty stright forward,
liners under wheel arch remove, then slacken upper screw at top of arch which attatches top of bumper to front wing.
remove frontgrill,remove and undo bumper fixings
disconnect fog lights
now the difficult ones to get at are between the headlamp and the wheel, under the flange of the arch is a 10mm nut thats a bit awkward but if you can get a socket on thats ok but the nut is plastic and moulded into the body if that don't spin when undoing bolt it's a doddle,(if it does )it's a bit awkward to get to plastic nut but not im possible (takes a bit longer).hope it make this makes sense.
MEG Colonel
cheers i'l pass this info on to our lass as she will be doing it, and putting my standard one back on :D
