1 - 11 of 11 Posts
Is it possible to remove the tinit film on windows?
I think this is more a DIY job on my mates Escort (previous owner) its too dark for him and he wants to change it.
Damo :L
LED Extraordinaire
Peel it off then you have to clean off the glue it leaves behind :L
does it need to be heated alittle to help? only problem is he is worried it may screw the windows up and then require new glass....
i used a hair dryer to get some writing off my back window and it helped loads, i must have used evertying until i tried heating it and it just peeled offf :whistling:
Likes to make the impossible just happen
Good old vinigar removes the glue and plastic get an edge and peel
Support the Vulcan XH558
Use an Haidryer..I did 'cos I got nicked and had to take me front ones off within 14 days...cost me a £30 fine too :(
Get someone to warm it up from the outside an you pull it off s.l.o.w.l.y, and yes there will be glue left behind, I used alsorts to get it off, meths, window cleaner and a sharp stanley knife blade to get it all of..
pull off what you can then get some soppy water and spay on the glue and a stanley blade and scrap of the glue this is how we do it at work dont wory it will not scratch the glass
1 - 11 of 11 Posts
