Hi
I replaced the radiator on my mk3 TDDI, and changed the antifreeze.The problem:
is that the cars temp is in the middle,
The engine is warm.
The fan kicks in.
But i have not got any Heat. It blows cold air even when on hot.
None of my radiator pipes is warm/hot.they are cold. Even after 20 mins of running.
Anyone help :(
TDDI Buff
sounds like you have an airlock take off the expansion tank cap and squease the bigger pipes
I second Totalguy's statement - air lock. I have a 2.0l SOHC Ford Sierra engined kitcar (Pinto engine) and airlocks are a constant difficulty if you have to break into the cooling system. The symptons are as you describe except that I don't have a heater. Cold pipes or warm lower extremities and cold tops on the larger hoses.
TDDI Buff
you bypassed what would be the heater radiator thats behind the bulkhead on a sierra i take it? motco
No Totalguy it's a Westfield (Lotus 7 replica) with a Pinto engine from a 2.0l Sierra or Granada, fitted with a pair of Dellorto 40s, Vulcam Maxflow head, and Kent Fast Road cam. But the rad is set more or less on a level with the expansion tank so getting the air out of the top hose can be a pain.
