the key fob part has two bits inside it, one bit does the remote control side and the other bit that looks like a little glass bulb is the pats chip that lets you start the engine.
your new fob does have the glass bulb and NOT the square block chip looking thing, the square block chip will never work on a UK spec car.
You do have 2 different old keys as well to put the car into learn mode to accept a new key to start the engine?
