1 - 19 of 19 Posts
· Megger
Hello all,
Can you haelp me again pls, with a step, by step 'idiots' guide to reprogramming the Full closure on the Mond' Mk3.
Everything worked very well - untill that is the car went for a new clutch. The battery must have been disconnected and as a result. When I kept the lock button pressed......everything OPENED!!!
Can anyone help?
Cheery cheers
Jon
· MEG Corporal
1. Turn on ignition so that dash lights but do not start engine
2. Lock the door using the lever by the door handle and then unlock the door (without opening it) 3 times
3. Turn off ignition
4. Repeat 2
5. Turn on ignition but don't start engine - a beep should sound
6. Lock the door again as before and unlock it
BUT ONCE ONLY
7. A final beep should sound
Done!!
· MEG Corporal
Oh bug**r - I have given the operation for autoLOCKING of doors on the move!!!
SORRY!!!
THIS is what you wanted
To reset the windows, follow these steps:
Hold the switch down until the window is all the way down
Release the switch then hold down again for 5 seconds
Press the switch so the window goes all the way up
Release the switch and press it up, again for 5 seconds
The window will now be set for one touch and global opening/closing. Repeat this procedure for each individual window...
· Just me
· MEG Corporal
I think it's the same principle starting with roof closed.
1. Raise roof, release switch press switch for 5 seconds, release again, lower roof, release switch and press again for 5 seconds
2. Repeat above for slide
Try it and see if it works.
· Registered
How does the global closure work when you want to deadlock the car too?
Do you press the lock button twice on the remote fob and then continue holding to do the global closure?
Does this work? I keep forgetting to try it when I leave the car! :eyesup:
1 - 19 of 19 Posts
