Since my battery went flat a couple days ago,my global closing won't work.It works ok when opening all the windows and sunroof,but will not close them.Also the one shot close on the windows won't work either.Is there a way to reset this?
Discussion Starter · #2 ·
UPDATE. Been operating the global closing and now it works ok except for the front passenger window will go down but won't close unless I do it manually.Sure someone said you could reset individual windows by pressing the window switch in a sequence.Anybody?
Thank You :thankyousign:
Went thru the button sequence,everthing works except the front passenger window won't close using global.But it will now lower using one shot.
Although it will not close using one shot.Any more suggestions?
