Hi - quick post with a resolution in case anyone has the same problem:
Car:
Focus 61 reg (2.0 TDCI 163 Titanium X, 6 speed manual)
Issue:
~ Car at stand still with the clutch up - able to select any rpm desired with the throttle
~ Car rolling with the clutch down - able to select any rpm desired with the throttle
~ Car at stand still with the clutch down - very light throttle causes revs to shoot up to about 1,600, followed by a slow drop back to desired rpm over a couple of seconds.
Issue results in:
~ When pulling away the car moves off and then the revs die back, causing the car to engine-brake unless lots more throttle is used.
~ When nudging forward in traffic, problem occurs many times and people think you can't drive
~ Driver thinks car is rubbish
Fix:
~ Powertrain Control Module software update to latest edition (factory edition was on the car from 2011/2012)
Result:
~ Revs do as they are told at all times and hold where you set them
~ Car is no longer rubbish
Additional advantage:
~ Indicated gear changes are assisted with automatic rev selection. For example - driving in 3rd and 4th is shown on the screen. Clutch down (ready to change into 4th) and the revs hold exactly where they need to be for 4th gear at that vehicle speed. Gear/engine speed is automatically matched provided you change to the gear shown on the screen. Does not work for change downs (as they aren't shown on the screen).
Cost:
~ £80 inc VAT, done at Ford
Expected comments:
~ My mate can do that for less - perhaps, but will it be the latest? I assume not.
~ That car is rubbish, should have bought the 140 - upto you, but I've got Titanium X toys.
~ Thanks for the post, it may help someone sometime - no problem, glad to to help.
Car:
Issue:
Issue results in:
Fix:
Result:
Cost:
Expected comments:
