1 - 7 of 7 Posts
· MEG Corporal
I assume you mean the (cross) bars? Does your MK4 have the rails (front to back) like in the photo? Even if you did it might not.
· MEG Corporal
Ok, then you need to work out where those bars have come from and check if they are the same part number for your car. Are they Ford bars?
· Registered
They're Fords. They differ in the catalog, but I have never had the opportunity to try them. The width and the rails themselves look identical. Often the numbers in the catalog differ even if the parts match. so I'm just wondering if anyone has any practical knowledge on the subject. ;)
· Big Megger
According to catcar, they are different numbers. If you look through catcar and compare the MK4 to the MK5 and see if it helps.
1 - 7 of 7 Posts
