1 - 10 of 10 Posts
so if my car has been sitting for a few hours, as soon as I pull away there is a small rubbing sound like I left the hand break on
also last few days when I break I can hear what it like no brake pads.
so had all 4 changed today, no sticky calliper reported back
could it be while bearing?
Sent from my SM-G965F using Tapatalk
There's a very easy way to check this. Jack up each corner and rotate the wheel.
To be fair, this is something that could have been checked when the pads were replaced.
thanks, the noise on breaking is gone, but still the small sound when first move the car.
I have the video of the sound but can't upload?
Rust on the edges of the brake discs?
Jack the car up and spin each wheel and see if ones worse than the other.
You can upload to Youtube and put a link in the post, the forum will show the video/sound clip.
Sounds can be rather hit and miss to record though, the microphones tend to amplify most
mechanical noises.
let's see if worked. few secs in. only at slow speed and first 10 mins after being parked up
Find an empty carpark or quiet road, get upto 20mph and dip the clutch and gently apply the handbrake.
Same noise?
As mentioned check the edges of the discs for rust.
Discussion Starter · #10 ·
ok so tried it at work a few times and even a few clicks on hand break and drove around the car park to no noises
8 hours later, as soon as I moved car made the noise.
on parking at home (12 miles away) as soon as I started to reverse the noise was there
1 - 10 of 10 Posts
