"Rubbing" noise @ 1500rpm
408 Views 2 Replies 2 Participants Last post by  Lord Greenville
As title - occurs whether clutch engaged or not.
? wheel bearing
? cause
:confused:
hi there
is it just at 1500rpm or all the time?
i've just replaced a rear hub/bearing because of a rumble sound.
the old hub could hardly be turned by hand. not what i was expecting. i thought it would be a bit wobbly.
explains why i was only getting 35mpg on a run recently. before i was getting nearly 40mpg.
jack it up and you will hear the bearing as you turn the wheel if it's bad.
hth
Just @ 1500rpm - all wheels seem to rotate freely and I'm getting 44mpg on short commutes so not likely to be a wheel bearing, then. Any other ideas would be welcome.
