I have a 2006 2.0 petrol S-Max that is not able to complete the System readiness test.
Using Forscan to do a mode 6 test, I get low misfire on different cylinders. It is not always on the same cylinders and can be on one or all. The value for misfire is generally below 1%
Font Terrestrial plant Screenshot Technology Multimedia
I also get a too high value under the “Voltage amplitude and voltage threshold” for Oxygen sensor Bank 1 Sensor 1. This can also change after reset of the module but generally stays above 700 mV.
The engine runs “OK” but not good. Seems to lack power, especially in 5th gear.
Spark plugs wear out fast. The below picture is of a spark plug that has less than 1000 km.
Household hardware Nickel Metal Engineering Auto part
I have been focusing on the misfire and have replaced coils, sparkplugs, camshaft sensor, crankshaft sensor, cleaned and tested injectors, intake shut off solenoid and PCV. The engine runs better than before but still not good.
My next step would be to replace the ECU.
Does anyone have similar experience or suggestions what could be wrong?
Air leak? Get some WD40 or similar and spray it around the inlet side of the engine and see if you get
a change in engine speed or sound. If the idle increases its sucking the oil into the engine.
System test can take a while and pops up every time you clear a code, you just need to put some miles onto
it so it can do a self test again.
