81 - 100 of 130 Posts
owner of the cleanest cd132 18 years old going str
Discussion Starter · #81 ·
engine bay clean up ,
Discussion Starter · #82 ·
brake fluid bottle cap , annoying the sticker is not facing the correct way
  • Like
Reactions: Ah Cougar
Master Cylinder cap, will it only go on in one place?
Discussion Starter · #84 ·
that's it done up tight , think the peps in the garage took the sticker & moved it to annoy me when doing brakes lol
no, what i mean is try undoing it, and turning it 180 degrees or whatever it needs, then try tightening it up, if i remember right they should fit with the sticker ending up in several positions.
There would be evidence if they'd been sticker peeling...
Discussion Starter · #86 ·
now with full size spare
Discussion Starter · #87 ·
few pic from fordfair
Discussion Starter · #88 ·
fordfair
Discussion Starter · #89 ·
rear window stickers removed
white IPS sticker had started to go brown
removed these rubber strips , drivers needs replacing big split along it
13 years of crap behind
Discussion Starter · #92 ·
Discussion Starter · #94 ·
Going to leave mine on then lol
Sent from my GT-I9100 using TalkFord.com mobile app
im driving around with the drivers side missing, don't know if it makes any difference to noise as there a lot of wind noise getting in anyway , get use to it in a mk3 lol
Discussion Starter · #96 ·
Mine does it well most cars ive had did the same
I find it the only annoy thing with mk3
Discussion Starter · #98 ·
Yeah thats only problem
I have set of the later seals that run along the top of the shell , the bottom bit is more chunky the bit u see in the door frame at dashboard level, but not show if this later chunky bits fits an early one
in my mind the most noise seems to come from wing area of frame
hope all that make sense
Discussion Starter · #100 ·
