1 - 7 of 7 Posts
Need to turn off my Service light on the mk2. I kow I have to press the button, but can't remember the sequence. Is it with Ignition only on or engine running?
Thx
mumbles
Same problem with mine, altough I've tried both and it didn't worked, is there any ide how to switch off the service light if the reset is not working ?
I Love Diesel
switch the ignition on. then press and hold the button in for about 4 or 5 seconds and the light will go out. you need a fairly long pin, like an unbent paperclip, and you need to press the button right in until you feel a slight click. this should do the trick. :L
Thanks, Twincarbs. Was using a biro, obviously not going in far enough.
Mumbles
wheres the reset button on a MKIII ?
I don't think there is one, it is reset by the dealer .
I also heard that there was something you could buy that plugs into the car to reset the MK3 service light.
1 - 7 of 7 Posts
