Slight Fuel issue
711 Views 11 Replies 3 Participants Last post by  rxt_ian
Can someone please explain to me why the car is doing 234 miles to a tank? :}
There's no fuel leaks, no smell of unburnt fuel anywhere, and the engine is still quiet and smooth (if a little gutless, although it does have a tendency to suddenly act like a 2.0, rather than a 1.6).
Will be remapping the car on the 28th to see if it that makes a difference, but I'd welcome your views in the meantime. :)
1 - 12 of 12 Posts
Do you have the handbrake on? :whistling: :}
Seriously, I'd be looking at the coolant temperature sensor (ecu constantly trying to warm up engine?) and lambda sensor (ecu cant smell how much fuel its throwing out the exhaust). Though I would expect that the exhaust would smell with either of those :shifty:
sounds like a faulty lamber sensor
Wouldn't it fail the MOT though if it was?
Yea i think it would fail...
If the fuel isnt going through the engine and coming out as exhaust emissions, you must have a leak somewhere, perhaps only when driving/running? When is the last time you checked the fuel filter?
Fuel filter was change at it's last service. (90k)
Coolant temperature sensor sounds like a likley candidate though, I'll change it at it's next service (Due for one shortly anyway)
Did your car pass the mot using this much fuel then? If it did I cant imagine it passed the emissions test burning roughly double the amount of fuel of a normal mondeo :confused:
You are managing to fit 60 odd litres into the tank every time you drive 250 miles?
Yep, it's total emissions was something like .003 or something crazy.
As far as I can tell yes.
Then as far as I know you must have a leak somewhere :confused:
id have to agree if it passed its mot with that low an emissions reading and using as much fuel as you say it is then you must have a fuel leak
I can't understand it though. Surely there'd be some sort of evidence? Puddles on the floor, the smell of unburnt petrol...... :confused:
It may only show itself when running? Spraying a little bit out all the time could throw out a surprising quantity...
Petrols pretty damn volatile so would evaporate away, I'm not sure if it even leaves a stain
1 - 12 of 12 Posts
