I bought my 2003 2.0 maverick last year with 30,000 genuine miles on the clock but it came with a low speed judder, when going at below 20 mph I get a judder like feeling from the car like it's kangarooing but as soon as I speed up it stops, it only happens at low speed I can sit at 60 mph and get nothing.
I have had it in the garage 4 times to try and get this fixed and they have tried everything now they are stuck, has anyone got any ideas before I go down the dealership route.
Any help will be greatly appreciated by both my self and my bank balance
what exactly is "tried everything"?
does it feel like the engine is moving/rocking on pull off from standstill?
any clunking sounds?
or would you say it was engine related (fuel/ignition)?
It only happens when driving slow, slow enough to go over sped bumps type slow it'll idle no problem and drives perfect, no clunking sounds at all, had maf sensor, erg valve sensor, spark plugs and leads changed and a few others things but still no luck, when da garage has no idea then hopefully I'll find out from here
