Did you use a proper Ford fuel filter? I replaced mine not so long a go and used a cheapish one and it fooked the car up. Went into limp mode. I was told that some don't have a good enough flow rate as the proper Ford ones.
Also when mine tends to seem a bit sluggish I use some Wyns injector cleaner in with a full tank, always seems to bring it back to its best and sounds a bit healthier too. Also brings the mpg up a bit.
Although 80miles to £20 does seem rather low. Is that town drivng, stop start etc?
