graysi said:
I spoke to the ford dealer where i bought the unit from, they said because my old stereo was different i.e 6000cd there was no WDS code to transfer, is this right.
What they need to do is the following
1: connect up the wds to the car
2: using the menu system on the wds they will be able to config the unit up so it work correctly.
What is happining is that the radio needs to be setup to the car. You setup items like what kind of trim is fitted, cloth or leather. What kinf of speakers are fitted. It will remove the display of the clock as you don't need it. It will be all setup with the vin number& proberly setup just to work with your cars ecu unit only. So if your radio was nicked, it shouldn't work in any others car we hope.
The problem is the the ford dealer has never done this before & is unsure what to do.
I don't that my ford dealer I use for parts didn't even know themself's how to do it until I told them what to do & what parts to use. :surprised: or :sad:
By the way, do you have the right center console part for the sony unit to fit right. ? If not you will need to order it from ford. It's about £50ish. To change it over will take about 2 hrs tops. I done a few console change overs, just ask MAV.
