It's a common fault on the Mk2, there's usually a problem with the fuel warning light at the same time. If this is the case then it's clocks out time (read the last bit carefully, i'm not being mucky) for you. There are also a number of other possibilities, one of which is the hall effect sensor on your gearbox. These are known to fail also.
Is it an intermittant fault?
This is the main reason for problems with Mk2 speedos. If you also get a low fuel indication at the time when it fails then this is the reason.
Link
