Hello this is my first post and I’m sure it has been covered before but looking for some help,
I have a 2006 mk3 mondeo st 2.2tdci, recently the speedo has started to play up it could go for 10 miles or less then drops to zero, it has got steadily worse and now it doesn’t work attal, as soon as you start the car the dashes appear that replace where the mileage is supposed to be, and Speedo doesn’t move.
work that I have already done is,
Change the battery
New wheel speed sensor
New wheel bearing
Cleaned earths from battery
also when the speedo isn’t working the car runs rough and has lack of power, but if the speedo decides to start working the car runs perfectly, I am also hoping to plug the computer into the car at the weekend to see what codes it shows up, has anyone had this same problem? And could maybe point me in the right direction
a lovely car to drive when it’s going right so keen to get this sorted. Any help would be much appreciated.
Mark
Change the battery
New wheel bearing
Mark
