Hey guys, was wondering if anyone could shed light on this problem...
My brakes are becoming spongy, but only after I turn the wheels. I press the brake and there's about twice as much travel as usual on the first press. When I release and press again it's nice and firm.
If I then drive on a straight road the brakes remain firm.
If I turn a bend and then brake they go spongy again. The harder the turn, the spongier it gets until it's almost down to the floor.
It's a '97 mk2 Ghia with hydralic clutch, which feels no different under any situation.
It seems as though some force is moving the pads away from the discs when cornering.
If it's any relation, just prior I had a regular knocking noice coming from one of the front wheels which got worse at speed, but has gone now. I haven't had time to check the brakes yet and in any case can't get the right front wheel off due to stripped splines in one of the wheel studs.
Has anyone ever come across this problem? I expect it's one of those unique problems that requires diagnosis but you never know.
Incidentally, my clutch pedal goes stiff after about half an hours driving - anyone know what that is? Been happening since I bought it.
Many thanks all.
Many thanks all.
