The stabilliser fits between the under part of the bumper lip,if you look at the bumper you will se 5 holes,this is where the stabbiliser attaches.
I gave Drew the template "cardboard",with the bumper,it will save you approx £80 on buying a
new one from Ford,ask Drew for it,or if it has gone missing,i will send you another,just send me
a stamped addressed envelope.
The part numbers are correct except the last one which is incorrect,the part number for the
large centre grille is that which LIXY has put up
,it's a problem for me looking through invoices
when all they are called is a cover or insert,
i have got loads to look through.
The reflectors are separate to the grilles and
the little griles that came with the bumper will
not be of any use,the new one's are different.
You will need to bond them together aswell
because Ford only supply them lose with no
fitting kit.The reflector fits to the grille
and in turn they attach to the bumper through
some holes at the back of which should be a
fastener.So what i did was cut the lugs down on the reflectors then bonded the two parts together,this will save you having to put some holes in the bumper.
I will put a pic up for you to see the stabillser
you need it,it's job as the name implies is to
stop the bumper flying off the car.
You just get a cement puddle from Wickes £16
and cut it out with a jig saw the plastic is ideal
as it does'nt crack and is very tough.
