I have a 2012 Ford Focus 1.6 diesel estate with a problem! The clutch master cylinder has been replaced due to the plastic plunger breaking - a common problem I'm told?
Since this repair the stop/start, cruise control/speed limiter, hill start assist and gear change indicator no longer work. Occasionally when stopped with foot on brake pedal a message appears on the display saying 'Hill Start Assist Not Available'. Otherwise everything works normally.
Forscan and ODB II reports the following:
P0807:00-2F Code: P0807 - Clutch Position Sensor Circuit Low
P0806:00-2F
Status:
-DTC Present at Time of Request
-Malfunction Indicator Lamp is Off for This DTC
Module: Powertrain Control Module
I found older posts describing exactly the same problem but with no conclusive solution.
I also read from other similar posts that the battery is a possibility, however this one has been changed recently and the problem was there before and after plus it seems too much of a coincidence that the problem started immediately on using the car after the master cylinder was replaced. It has been suggested that the wrong master cylinder has been fitted - is this possible?
Both clutch switches have been checked on and off the car. In any case I assume the bottom of travel switch must be OK since you need to depress the clutch to start the engine.
The top of travel switch has a good earth reading on the black/grey wire and the other wire has just less than 12volts on it until you depress the clutch when it falls to zero.
Before starting the engine the light in the stop/start switch is not illuminated. When the engine starts the switch illuminates 'off' after a few seconds. Pressing it after this point makes no difference - it remains illuminated 'off'.
Curiously with the ignition on and the engine off and the clutch pedal up or depressed the light in the stop/start switch goes on and off when you operate the switch.
Any suggestions would be gratefully accepted, thanks in advance.
Regards
P0806:00-2F
Status:
Regards
