Spring load details can be found on etis, we have covered this before. If you look on etis it would maybe show up on a search on here?
To the best of my knowledge, there is the Titanium X Sport/ Energy Efficient model (not sure of the name) that have lowered sports suspension (30mm drop).Hello?
I'm pretty sure its just the springs that are different on the Titanium X Sport/ Energy Efficient models - the shock absorbers and anti-roll bar are the same unfortunately. Ford offer a Eibach (springs) and Bilstein B8 shock absorber upgrade path but anti-roll bars are in short supply with the rear one being slightly less than ideal for the Titanium X Sport.Cheers.
I'm not keen on lowering the car as I want to retain the ground clearance.
If nobody knows what the other differences are, I'll have to try phoning a Ford dealer, but they'll probably know even less....
It would be Interesting if the dampers and ARBs on all Mondeos are all the same, but some springs are stiffer -Some of the setups would presumably less than ideal.I'm pretty sure its just the springs that are different on the Titanium X Sport/ Energy Efficient models - the shock absorbers and anti-roll bar are the same unfortunately. Ford offer a Eibach (springs) and Bilstein B8 shock absorber upgrade path but anti-roll bars are in short supply with the rear one being slightly less than ideal for the Titanium X Sport.
http://www.etis.ford.com/what is this etis site mentioned on here and how do i go about using it
