Vehicle: 2001 Ford Mondeo Estate
Engine: Duractec 2.0, Code: CJBA
Trim: Ghia X - Black Leather Interior
Initial Inspection of vehicle at dealer indicated the following problems:
- Swirl Flaps rattling
- Drivers Seat Height Adjustment not working
- Drivers Seat Cushion torn (repaired with black duct tape)
- Drivers Seat Bolster split (repaired with black duct tape)
- Front and Rear Discs heavily worn
- Towing Eye missing
- Only one, badly worn, key available
No service history was available for the vehicle.
Having purchased the car, on the drive home, it was noticed that the coolant temperature indicated on the dashboard never moved off the bottom stop, except on restarting the car having stopped at a garage to check tyre pressures. The coolant temperature quickly returned to the bottom stop as soon as the car was moving again (Outside Air temp was just +2 Degrees C).
Subsequent post-purchase inspection has foudn the following problems to date:
- Induction Air Filter heavily soiled
- Pollen Filter heavily soiled
- Drivers Seat Belt very stiff (Dirt?)
- DTC P0125 reported by FORScan/Vgate iCar - "Insufficient Coolant Temperature for Closed Loop Operation"
- No Radio or Key Codes supplied with vehicle
The post-purchase inspection is still ongoing. Further problems will be updated in the list above until I'm happy to start driving the car.
I intent to remove the inlet manifold to inspect the swirl flaps, and will replace any worn parts. I will also remove and inspect the coolant thermostat while the Inlet Manifold is off. I don't intend to drive the car until this work is done.
I'm trying to avoid spending money on fixing the other problems until I know whether this car has a future with us...
