Good evening
I am thinking about buying a 52 plate mony 2.0TDCI 130, its done 48K and looks mint inside. Anything I should be looking out for on this model, and also when does the Cambelt need changing
Nick
hi my car is same as the one you are thinking of buying, my local ford dealer charges me £128 for small service, and £175 for major service but have just found small independent garage that charges a lot less and does a better job than main dealer, so i would suggest you shop around to find the best deal hope this helps. :L :L
Servicing varies, I pay about £130, unless its already been done you will need new rear subframe bushes at some point, if its not under warranty it will cost the thickend of £300.
As for any more problems, not really, injectors can sometimes fail, have heard of conrods failing, although not that widespread.
Dan,
