Noticed this before but it has just started to niggle a little...
if you stop the car and gently raise the revs to between 1750-1900 and hold the throttle STILL, it suddenly drops to 1750 and slowly rises to 1900 then dops again, it just keeps doing this.
Accelerating through the gears is fine or just revving through that range is fine, but if you are driving slowly and you hit that engine speed it does the same thing and i resemble a learner driver at the lights!!!! kangaroo juice!
any ideas? if its gonna be expensive i will just leave it as it doesn't bother me often enough to spend a fortune!!!
