Mk1 - Fan Sender Sensor located in the top of thermostat housing. Temperature gauge sensor located in bottom of thermostat housing.
if the thermostat dont work there is a possibility that the fan sender sensor will not do his job???????
my mk2 black top 2lt as mine as a temp sensor and a sender i know there is 1 at the top and one under houseing
my blacktop has a metal housing not a plastic one...does this mean it has two??
covlad1987
have look under the housing front right place to stick it lol ones a sender the others the temp the top one as a drop of water on it so i thinks its knackerd
im not sure if mines metal
